Does this wheel set-up work?
anthonysnell
2" level with 20x10 -18, 33"x12.5" Tires with no rubbing, no trimming. Will this set-up work.
Any examples would be appreciated. I've seen many examples working in the 4th generation and not sure if one could assume it will with 5th.
Thank you in advance for any feedback, help.
Yes this set up will work, I am running a 2" level with 20x10 -24 on 33"x12.5" with no issues. Zero rubbing.
Thank you for letting me know. Would you kind sending me some pics of your truck. I would love to see how it looks.
Thanks again
here you go
here you go
Great looking truck...thank you for the pics. Love your taste and very much the look I'm wanting but hard to speak to anyone that has done it. Could you let me know the following;
1. You've had no rubbing issues in full-turn, both sides in reverse and drive?
2. What type of lift did you go for?
3. What brand of tire did you go forward with?
4. How is your ride quality and road noise with the tires?
Thank you
Anthony
Thank you for the kind words, I still have few little details to get done but almost there.
1) no rubbing issues at all, full turn clears by at least 1inch away from the fender liner
2) I have "2inch level kit from readylift.
3) I am running the BF Goodrich Ko2
4) The ride quality is nice and smooth I love it, and the tires are pretty quiet, to be honest. It's a big reason why I went with these tires.
Hope this information helps man!
Thank you again my friend. Keep me posted with any other updates on your truck. I looked up your tires to read up further on them I couldn't find the 33x12.5 but did find the 305/55's and assume that's your size.
Yes those are it, Its pretty much equivalent to 33's when you convert it to inches.
No problem will do for sure.
Has anyone had success running 305/55r20 on a 20x10 -18 wheel without a leveling kit? I have the air suspension so I can’t level. I do have the Off Road Package so I have an extra inch. I’ve read through a lot of posts, but I’ve haven’t seen anyone with this specific set up.
I put 35x12.5 on the stock 20. Had minor rubbing but do not have off road package. I also have air ride. I think you will be fine.
So before I order my tires. 2 inch level kit would fit these tires no rubbing at all?
