Check engine light when truck off
Mch5jdm
Michigan
Is it normal that the check engine light is on when my truck is off but in the run position. Just noticed it when I sat out in my truck for lunch break and cycled the start button to the run position so that my radio stays on.
It goes out and has never came on when running.
Jako
Borough of Parks
Why Run and not Acc for radio? I see join date is April 2019, is that same for truck? What type of shape is battery? My Ram would not come out of 1st gear one day because of an old battery (2 years + old).
Fatherof3
Ontario Canada
Yes that’s completely normal if you’re in the run position .
Mch5jdm
Michigan
Thanks. I figured but it was hard to find info on this. Knew you guys would know.
Mch5jdm
Michigan
It cuts out after 15 min. I joined before purchasing as I was researching the 5G
