Jeffjad
Southwest PA
Seen these on Facebook so thought I would give them a try. Built right Velcro panels and bags with assorted d rings and elastic clips. Let’s me keep everything off the cab floor and organized. Will hold all my PPE gear for work and then some.
Sweet, can you post the link to these. Thanks!
brian1684
Keokuk Iowa
‘19ramlveryeha
Now that’s a nice.
Gitter
Texas
Alright here is the install video for the Evil Mfg 3rd brake light.
In full transparency, this is not a mod for the novice. There’s a considerable amount of wiring and some grinding/cutting required to fit everything together.
Super long video but there are a ton of steps and wanted to make sure I covered them all.
Enjoy!
Heck yes, great video! Thanks for all the details. Your truck is looking awesome!!
Now all you need are the side facing lights to give you a full 360 (and to fill in that 4th slot in your switch).
1awesomelaw
Where did you order those panels from?
Are they just Velcro to the bottom of the seats?
1awesomelaw
Had to brush the dang snow off my truck after work! Only I’ve already taken the winter stuff out of my truck...So much for spring, thanks Vermont. 🤣
Snowing here in Massachusetts this am.
1awesomelaw
Does the windows have a safety up feature, so when these are installed and the window goes up, when it hits them does it force the window to go back down or can anyone install these?
Could I please have the Mopar order #. Thank you.
RickWaz
42.524603, -83.756544
Pictures simply can’t do justice to how much different this looks in person from where I started. Really satisfying results from ceramic coating. I’m excited to see how it performs and holds up over time now
Looks like you missed a spot ... driver's side Ram Box ... upper right corner .... JOKING! That Ram is INSANELY Bad A**!!!
RickWaz
Swapped out my Michelin® Latitude® X-ICE® XI2 winter tires for the OEM Falken Wildpeak A/T tires, on a day when we were going to get ~ 4" of snow. It's late APR in MI, so winter weather is almost over! Put them on in early NOV, and due to the panDAMNic and working from home, I only put 1,100 miles on the Michelin's in 5½ months. At that rate these winter tires will last about 40 years!!!
Godscountryrider
Might as well drop an update.👍 over this week I added 1.5” wheel spacers. Hood/ fender stripes & an mbrp exhaust. Simple bolt on. Kept resonators. Nice change in tone. Not to loud. Got more planed😎
brian1684
Keokuk Iowa
Link is a few posts up. Built right industries is the company. The panels are just Velcro they attaches directly to the seat bottom. Holds pretty good. Comes with some d ring and elastic clips to attach things, the bags have long button snap straps that go through the slots on the panels. I can fit a full size hiviz rain jacket in the big pouch, and 2 Hivis safety vests in one of the smaller ones with room to spare. It was $180 for the full set up, which is a bit pricey, but it was the best option for what I wanted.
DONZILLA
All you do is ride them up with your hands on both sides and the window learns not to stop.
