Muffler
CanadianRam19
Could someone recommend a nice throaty muffler, my super 10 flowmaster isn't all that what it use to be on my mustang's...
I would like a muffler that rumbles not only when you start it ,but every gear and at a stop light..
Also should I leave the resonators on or not ?
Thanks
Fuzznutz
Full exhaust system vs Muffler swap.
Sent from my SM-A505U using Tapatalk
Fuzznutz
Truck virgin | How do I make her loud?
mcp6530
Chicagoland
Has anyone compared the flowmaster 50 delta with the pro series? looks like the pro will provide a bit more sound without going into the 40's and the drone issues.
brian42
San Diego, CA
If you want noise/rumble all the time you might want to consider deleting the muffler instead of replacing it.
If that's not an option, and drone is not a concern, then there are plenty of options out there for a direct-fit or replacement muffler. Rule of thumb is the shorter the muffler the louder the exhaust.
There are too many options to list (Flowmaster, Magnaflow, Carven, Borla, B2 Fabrication) that make direct-fit stuff let alone mufflers you can have a shop install. Got Exhaust (www.gotexhaust.com) is a sponsor here and has a lot of options.
My recommendation is to read up and find some options you are interested in then cruise over to Youtube and search for some of those. There should be plenty of videos of people showing off their new mufflers. Many websites have videos as well showing the difference with their exhausts.
Watching videos isn't the same thing as being there but it's as close as you're going to get to find what you want without having a buddy's truck to listen to or just taking a blind leap of faith that you've found your rumble box.
SD Rebel
San Diego, CA
Flowmaster Outlaw, 60s muscle car sound all the time except when cruising at a constant throttle, then it's quiet when you want it. Rumble when you want it.
I've owned a lot of cars and trucks with aftermarket exhaust, I've never gotten so many compliments on the sound of one than I do with my RAM with an Outlaw. This is with all of my resonators in place.
Fuzznutz
That is with resonators still intact^^^^
Fuzznutz
how bad is the drone?
I don't personally think it's bad at all, but as I said in the other post, I'm coming from 15 years of owning straight piped diesels. It is worse when mds kicks on, but that's simple to turn off. I think people say towing with the outlaw has a good amount of drone, and I can see that. But I'm not towing much, so non issue for me.
