Power Side Step Question
Nozzleman
So I would like to buy power side steps and one of the guys here mentioned that you could control them from the radio.
My question, is that a certain brand or does it have to be OEM?
Sent from my SM-N970U using Tapatalk
Neurobit
RAM Sorcerer
Texas
Got it. So, when it connects to the radio, is it that you can just deploy them from the radio?
Correct. You can deploy them manually from within UConnect.
IvoryHemi
You can also set them to auto deploy/retract in the settings menu
RebelWraith
Polymath
Montclair, Va.
Awesome! Thanks
One thing to note the integration with the BCM will not work unless the dealership inputs the sales code or you use AlfaOBD to enable 3 options.
The power steps will work with door opening and closing once all the wiring connections are made though.
Nozzleman
Can I use a Tazer DT?
clazer
Or you can get Amp power steps and the optional switch module, which I mounted near the sensor toggles. Or anywhere.
Nozzleman
Do you have a picture of the switch?
RichM1983
I added the steps but don't want to go to the dealer to add the options on the radio. What three changes to BCM have to be made to enable the options on the radio?
RebelWraith
Polymath
Montclair, Va.
