19RamBC
Heres a solution to add the roof marker lights to our trucks with sunroofs..
Shop Our Products
www.autoventshade.com
Yes i agree i don't mind the low profile look, and painted the same color of the truck would blend in nicelyNot gonna lie, that actually looks pretty cool. I'm not a big fan of those massive light bars some people have across the windshield, but this has a really low key look to it.
If you look in the instructions it shows you tuck them under the gasket for the side of your windshield or it comes with a gasket with 3M tape you run along your side of the windshield@19RamBC I really like the look of that bar, but browsing the web it sounds like they are no drill. How do you run the wires and keep them hidden without any drilling?
There is 2 models one for sunroof and one for not.. also they can be trimmed around any other front antennas as per the instructions>Excludes Rebel models
What possible difference could there be with the front roof of a Rebel that's not on say a Big Horn, Laramie or Limited?
This is without the sunroof & the shark fin is on the rear of the cab.
I should have mentioned that my explanation was for my truck.. no sunroof & rear shark fin. That was my bad.There is 2 models one for sunroof and one for not.. also they can be trimmed around any other front antennas as per the instructions
My question as well. Why is the Rebel excluded?>Excludes Rebel models
My thought would be that since the Rebel is more of an off road design,>Excludes Rebel models
if you used a fuse tap and used a fuse position that comes on when the car comes on as your trigger wire for your relay to drive the lampsDoes anyone know how to wire this up so it’s on whenever the car is on. I guess maybe wire it up to the drl’s but which wires off the headlight harness would that be. Thanks in advanced.
On my only truck which was a gmc at4 I just tapped the drl wire off of the headlight harness and worked out perfectly. This is my first ram so I don’t know which wire is the drl. I need to find which one is the drl and which wire is ground. Any help would be greatly appreciated. Thanksif you used a fuse tap and used a fuse position that comes on when the car comes on as your trigger wire for your relay to drive the lamps
So, I just had one of these delivered today, and it doesn’t fit on the ends at all. Like, the one I got is tapered up on the ends. Doesn’t look like yours. I ordered it from Real Truck. Item # AVS-698173. For a 2019-2021 with sunroof. I actually just submitted a return request. It’s unusable for me. I’m wondering if what I got was mislabeled or something. Did you modify yours at all? I already repacked the one I got, or I’d take some pictures to show how messed up the fitment was.For anyone curious, I went with the AVS Aerocab lights. They turned out pretty good and were really easy to install.
I didn't do anything special with mine. The only thing that was odd when installing mine was that they had the polarity reversed. A quick flip of the wires fixed that.So, I just had one of these delivered today, and it doesn’t fit on the ends at all. Like, the one I got is tapered up on the ends. Doesn’t look like yours. I ordered it from Real Truck. Item # AVS-698173. For a 2019-2021 with sunroof. I actually just submitted a return request. It’s unusable for me. I’m wondering if what I got was mislabeled or something. Did you modify yours at all? I already repacked the one I got, or I’d take some pictures to show how messed up the fitment was.
I’m now seeing where they say that Rebel models aren’t compatible. That was not said on the Real Truck site. Blah.I didn't do anything special with mine. The only thing that was odd when installing mine was that they had the polarity reversed. A quick flip of the wires fixed that.
I did notice there were different bars for different makes/models. I had to be careful to get the correct one. The item number on mine was: 698163.
Hey I ordered mine, and have the same exact issue! Did the different model work for you, if you tried that? I ordered the 698173 because I have the 2019 Limited w/ Sunroof.So, I just had one of these delivered today, and it doesn’t fit on the ends at all. Like, the one I got is tapered up on the ends. Doesn’t look like yours. I ordered it from Real Truck. Item # AVS-698173. For a 2019-2021 with sunroof. I actually just submitted a return request. It’s unusable for me. I’m wondering if what I got was mislabeled or something. Did you modify yours at all? I already repacked the one I got, or I’d take some pictures to show how messed up the fitment was.
