No Off Road 2 with Air Suspension
MidTN21Rebel
Nashville
Brand new member to 5thGenRams, and I apologize if this has been addressed already ... I have a new 2021 Rebel with the air suspension, and when I try to put it into Off-Road 2, I get a notification on the dash that states "the selected ride height is not permitted". Any ideas? I appreciate any knowledge you can share.
CaptainCJ35
Rebel's and other RAM 1500's with the Off Road Package don't have the OR2 setting. Your "Normal" setting is essentially OR1 in other trucks.
Neurobit
RAM Sorcerer
Texas
Thanks! Appreciate the response.
Welcome to the forum!
Pls add your truck's vitals to your signature when you have a moment. This makes it easier for other folks to help in case you have questions or concerns about your vehicle.
CogitoErgoLevo
Los Angeles
If you have the 5 modes for air suspension which show as 5 lights then there is something wrong and you should have dealership look at it.
Off Road Group only has 4 settings and therefore 4 lights, and don't have access to OR2.
Are you trying to get into OR2 while driving? Cause it will not work above 25mph and should show you message like you the one are seeing.
Skyalkov
Are you talking about the highest setting? It’s only available under I believe 25 mph. Anything over that will max out at normal. Can use normal and aero at any speed. Entry is limited to 20 mph.
IvoryHemi
correct 25 mph for the highest setting, but it’s only 15 mph for entry/exit mode
