Plasti dip badges?
kingkasc
Hey guys I have a blk edition 19 bighorn and I’m adding some red accents(red caliper cover,red rimtrim) now I’m thinking about doing a red trim on my Bighorn and 4x4 badge.. anyone have success with plasti dipping the badges and do they? My truck theme is mostly black with some red int/ext. thanks!
Should work out great. Have Plasti-dipped many badges, wheels, grills, with great results.
Plenty of YT videos to show you how. Really simple.
Your the man! I plan on messaging you any questions I run into. Thanks boss!
This is the goal but with the Bighorn emblem as well!
It will be tricky since the outline is so narrow and the PD needs a decent surface area to bond, otherwise it will peel off. That's why you need to apply 4 coats minimum.
But paint it would be easy peasy?
These puppies ready for paintin!
Hey all. Was trying to plasti dip RAM grill letters. They are black badges, but I wanted them Del Red Pearl. I put 6 coats of black base and 6 coats of Cranberry Pearl Pearlizer. It came out lighter than expected, based on cap coloring. Any tips on how to darken the result? Would it help to do 2 coats of cranberry, then a light coat of black, followed by 3 or so coats of cranberry? Thanks.
Buy overlays in a closer match. You aren't going to get close with dip for that color.
True. If you're doing blacks/greys, you can get away with it, but matching colors will always be difficult to do.
Thanks, gents. Appreciate the confirmation. I did try the alternating of colors, but as you predicted, no joy. I just blacked them out again.
That looks miles better. Congrats.
For the grill letters are you taping them off? How are you doing it? I just did the door and tailgate badges, but couldn’t figure out a good way to attack the grill letters.
I pulled them off and sprayed them on some cardboard. I did not fare well when I taped them off. I pulled the edges up. I may have done better had I tried it a 2nd time but I didn't want to chance it.
