Anyone else???
socalboy951
Anyone else have a wobble at 65+. Im wanting to lift and put different rims on im wondering if the wobble will go away??
Snofire
WI
More information on the vehicle you have would be helpful. How is the toe on your vehicle?
vincentw56
No. When's the list time you balanced and rotated the tires? More info would help.
2020 Bighorn Night Edition, 5.7 Hemi w/eTorque
LakesAZ
Northern AZ
I don't have a wobble at any speed but I did have it in one of my other vehicles. Which was fixed with a Road Force Balance at Discount Tire.
socalboy951
Its a 2019 bighorn and feels wobbly in the stearing wheel when i get upto 65 to 75. I have only had the truck for 5 months it does have 23k miles
socalboy951
I may have to try that whats the going rate for a road force balance??
GRB60
Harleysville PA
First, verify that tire pressures are correct and equal. Next, inspect the tires for unusual wear that might indicate an alignment issue. Next would be balancing. After that, rotate the tires and see if the wobble changes, which would suggest a tire problem, perhaps a broken belt. If it doesn't move that suggests the truck so get the alignment checked.
Good luck.
nburd
Coast of Maine
Get your tires Road Force balanced. If it’s tire related it will find it and correct it or tell you that you have a bad tire or wheel. Many Ram dealers do it and some tire shops. They use a Hunter M9000 balancer and it’s always a perfect balance.
Hydroblueguy
I had all kinds of vibration issues and wobbles, replace many front end parts, many parts with no fix, after multiple attempts to fix it. With no fix😩🤷🏻‍♂️ I pressured them to buy it back and they did, I was starting to file my lemon law case! Good luck, no fix, mine was a 19, I’ve read people still having same issues with the 2021’s. I hope mine won’t have that problem again!
Hydroblueguy
Mine was even felt at lower speeds, so bad my side mirrors would be pointing towards the ground. I had to readjust every few days and tilt them back upwards. I was the only person who ever drove this truck at home!
Hydroblueguy
I paid $10 per wheel, $40 total at my local Discount Tire.
I had 7 tire balances in under 8000 miles, they tried telling me that was normal😩 even after road force balance, it was out of balance in 200 miles, truck never went off road or never hit curb or anything!
