Help. Does anyone have a listing for sway bar bushings?
Bighorned
Moscow, PA
I found my clunk. My motofab 2 inch leveling kit helped kill my front sway bar bushings I believe. Have a clunk going over bumps now. Everything else is tight and no play. Thanks.
I took the top spacers out. Still clunking on bumps. 99 percent sure sway bar bushings are worn
Looking for the bushings. Wanting to know which mm sway bar I have. Can't seem to find it anywhere
so I replaced the sway bar bushings. Moog ones. No more squeak. They were bone dry and worn in 25k miles. Now I still have a clunk over bumps first thing in the morn and seems to go away as I drive for a while, or at least gets quieter. I have no idea where the heck this is coming from. every bolt on front susp. tight. Any ideas guys??
Did you ever figure this out? End links?
I am having the same issues. Any fix yet?
You can temporarily remove your sway bar and end links to narrow down suspension clunks. I have thought about removing mine permanently, but ended up just replacing the sway bar bushings every fall.
End links. I had the same issue, and my end links are so loose I can make them move just by shaking the link around with my hand. Took my sway bar out completely and no clunk.
