REMOTE STARTING  SYSTEM
The remote starting system will allow the vehicle to be started  from distances of up to approximately 100 m (328 ft.) away from the  vehicle. It operates using the remote keyless entry key fob which  is part of your ignition key.
In order to remote start your vehicle, the hood and all the doors  must be closed.
To remote start your vehicle, press the REMOTE START button on  the key fob twice within three seconds. To indicate that the vehicle  is about to start, the parking lights will flash and the horn will  sound briefly.
Once the vehicle has started, the engine will run for 15 minutes.  To cancel remote start, press the REMOTE START button once.
The parking lamps will remain illuminated to indicate that the  vehicle has remote started and the engine is running. The lamps will  turn off when the ignition is turned to RUN or the remote start is  cancelled.
To enter the vehicle while the engine is running during a remote  start, you must first unlock the vehicle using the UNLOCK button on  the key fob. After the vehicle is unlocked, you have 60 seconds to  enter the vehicle, insert the key in the Ignition and move it to the  RUN position, otherwise the engine will cancel remote start and automatically  turn off.
Remote start will cancel if any of the following occur:
- If the engine stalls  or RPM exceeds 2500
- Any engine warning  lamps come on
- The hood is opened
- The hazard switch is  pressed
- The transmission is  moved out of park
- Low fuel indicator  is on. Low fuel levels
- The brake pedal is  pressed before the vehicle door has been unlocked. If you remote start  the vehicle while inside the vehicle and press the brake pedal, the  vehicle remote start will cancel
The vehicle can be started remotely up to a maximum of two times.  The vehicle is also allowed a maximum of one failed start. This is  where the remote start sequence was initiated but the engine stopped  cranking without starting. After either of these conditions, or if  the Vehicle Theft Alarm is alarming, or if the PANIC button was pressed,  the vehicle must be reset by inserting a valid key into the ignition  and moving it to the RUN position, then back to LOCK.
