antwon412
- Dec 18, 2019
Pretty much a non-answer, but I understand they probably have to say that for liability reasons (and, to their credit, they answered my question quickly).Thank you for reaching out! We arent able to calculate an accurate rating for the roof rack systems due to multiple factors such as terrain, driving style and load distribution. We do recommend basing your load rating off of the OEM roof load ratings since our rack will always be stronger than the roof of the vehicle it is on.
This rack permanently mounts with screws, and requires drilling into the roof of the vehicle.In order for the SABICs [Side Airbag Inflatable Curains] to work as intended, do not install any accessory items in your vehicle which could alter the roof. Do not add an aftermarket sunroof to your vehicle. Do not add roof racks that require permanent attachments (bolts or screws) for installation on the vehicle roof. Do not drill into the roof of the vehicle for any reason.
I appreciate that sort of customer service, which is not something I see often.Thank you for reaching out. I went ahead and canceled that order for you. I understand why you would be concerned. Your safety is a much higher priority. Let me know if you have any other questions or concerns.
I did come across that 165lbs figure, not specific to the Ram. But I'm pretty sure that's the dynamic, on-road rating. Static weight limit should be much, much higher: After all, vehicles are required to support a multiple of the vehicles own weight on the roof for rollover protection.Found something online stating that rule-of-thumb roof weight limit is about 165lbs. These heavy-duty racks can weigh about 70lbs. That leaves less than 100lbs for everything else, and that's static, not dynamic.
So, for most vehicles, running a lightweight rack with 3-4 mountain bikes is pretty much maxed out.
Really makes you wonder about those folks running fuel, water, tools, spare tires and everything else on their roofs, eh?
Thanks man. I'm trying my best to get there sooner rather than later. The sliders are done and I am working on bumpers. Roof rack will come after bumpers. I need to get my hands on a truck with Ram Boxes so I can make a rack that works for them as well. My work space is getting over run with jigs.you need dude to make one the guy in AZ that was making rock sliders. i told him i need a roof rack also, theres 2 sold right there.
@Ryno_B79 ^^
i think if you used some square tubing and cantilevered it off a headache rack, with some wedge shaped support gussets at the welds-Thanks man. I'm trying my best to get there sooner rather than later. The sliders are done and I am working on bumpers. Roof rack will come after bumpers. I need to get my hands on a truck with Ram Boxes so I can make a rack that works for them as well. My work space is getting over run with jigs.![]()
Yes I doi think if you used some square tubing and cantilevered it off a headache rack, with some wedge shaped support gussets at the welds-
you still got my sketch boss ??
