Auto headlights not working after I activated DRL's
LRHowland
I have Alpha OBD and USB connection for my 2015 Ram 1500. I activated DRL's and now my auto headlights no longer come on when it gets dark.
Thank for your assistance.
kdoublep
USA
Do you mean you switched your drls to different bulb? Like low beams to turn signal? Because I just did that 2 days ago with AlfaOBD and no issues so far. Everything is as it should be.
UnloosedChewtoy
5thGenRams Supporter
South Dakota
Welcome to the forum!
I'd recommend posting this in the 4th gen Ram section (or maybe a mod can move it for you?), as this is the 5th gen section (2019+) Rams. You'll get much better responses, typically, from the section dedicated to folks of the same Ram generation as yours.
That being said, if you turn the DRLs back off, do your auto headlights start working again?
