Do you mean you switched your drls to different bulb? Like low beams to turn signal? Because I just did that 2 days ago with AlfaOBD and no issues so far. Everything is as it should be.
I'd recommend posting this in the 4th gen Ram section (or maybe a mod can move it for you?), as this is the 5th gen section (2019+) Rams. You'll get much better responses, typically, from the section dedicated to folks of the same Ram generation as yours.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
