4wd. I own it. Plan on getting better tires down the road when the factory ones wear out. I was just wondering about the ride with a front leveling kit? Is it more rough? Less mpg?Is your truck 2WD or 4WD? Are you wanting the front leveling kit to raise it, or the rear leveling kit to lower it? Either way, it’s mostly for looks. The Ram trucks have always had a significant amount of rake that most don’t find very appealing. To a lot of us, level just looks better.
I'm at the same point you are. And extracting some great info from the experiences here on this forum, I'd go the leveling strut route. Thats the way i plan to go. Problem is, getting your hands on a strut now because they are on national backorder. The most recommended leveling struts round these parts are the Bilstein 5100. In fact, there is an entire thread dedicated to it. Check it out and you might get some ideas.4wd. I own it. Plan on getting better tires down the road when the factory ones wear out. I was just wondering about the ride with a front leveling kit? Is it more rough? Less mpg?
