Hub Centric Rings for XD wheels
Boxxer
Dallas, TX
For any of you that have XD wheels, where did you get the Hub Centric Rings? I tried to buy some aftermarket through summit racing at 77.8mm but they did not fit into the XD wheel. I do not see any 77.8mm sized Rings through KMC's Wheelpro Gallery as well.
XD82229067718 20" x 9" 6x135.00 /6x139.70 18 5.71 MATTE BLACK 106.25 2500 $340 M-959SB 1.9
So, upon looking some more...I found that the bore on the new wheel is 106.25mm
Since the hub is 77.8mm on 2019's...do I need a 106.25 x 77.8 Hub Centric Ring? or do I need a 106 x 78.05 ring? Sorry, new to this aftermarket thing.
I believe our Hub bore is actually 78.1, without having measured them with calipers myself. I've seen 78.1 more times for the '19s than I have 77.8. I picked up 106-78.1 rings for my wheels and they fit perfect on the hub and in the wheels. So yes 106-78.05 will work.
The hub bore is 77.8
Is it better to use 106.25 x 78.1 or 106.25 x 78.05 on a dodge ram 1500
Did the 106x 78.5 rings work out for you ?
