Air suspension bleeding off?
Avalanchez
Colorado
Hi, I have a 2019 ram limited with air suspension. I've been noticing it not sitting level when I leave it off for a while. When I open the door or turn it back on I can here the pump engage and level things back out, my question is is this normal behavior? Are they supposed to bleeding off/back? Is it a temperature thing? It is cold here. Any info would be appreciated.
Thanks
mine do that too. looks like the rear lift up a little after few minutes on park. it’s cold where i live also. compressor kicks for like 2/3 seconds
Funny...mine does it mostly when the temps are warm, and it's the front that sags. Glad I'm not the only one that sees it. Once I open the door to get in it levels out.
They will do that after sitting for a little while . I believe it’s so it doesn’t drain the battery by keep self levelling when the trucks not running .
Thanks
Normal. Updates the level only when it thinks you’re around to admire its handiwork. And yes, it will adjust after sitting a while, no matter the temp.
