georgesrt2020
- Jan 29, 2021
2021 RAM LED CENTER HIGH MOUNTED STOP LAMP W/ CAMERA - Anyone have any water leak issues on the back glass or headliner ?
Installed the 2021 led light with camera on my '19 Rebel and have had zero issues. The seal is more robust than the seal on the other center high mount light.2021 RAM LED CENTER HIGH MOUNTED STOP LAMP W/ CAMERA - Anyone have any water leak issues on the back glass or headliner ?
Did you install the same screws from the old light or did you order a different Size / Part# screw? Also did you hook up the camera or just bought it for the LED light ?Installed the 2021 led light with camera on my '19 Rebel and have had zero issues. The seal is more robust than the seal on the other center high mount light.
The new light only uses two screws and two clips which are included. The camera so far cannot be integrated on 2019-2020 DT Rams.Did you install the same screws from the old light or did you order a different Size / Part# screw? Also did you hook up the camera or just bought it for the LED light ?
