2019 Ram Rebel with Method 305 Wheels
Derek Dredger
United Arab Emirates
Hi'yall.
Just finished the below installation on my (granite crystal metallic) truck. Looks fantastic if anybody else is considering a similar setup;
Wheels:
Method 305 Bronze
18x9
PCD- 6x139.7
Offset -12
Tires:
Cooper AT3 XLT - 295 /70 / R18
Lift:
Achieved using Bilstein 6112 shocks and coils up front (ring 7) and 5160 in the rear. No wheel spacers and no strut spacers.
Mild 1-3/4" front. 1/2 Rear.
No rub at all. Clearance is approx 1cm in the front at full lock. Tires sit pretty much flush with the fender...probably stick out 3/4 inch.
Looks great, -12 Methods on 34" tires is the combo I'm going to do as well, your truck definitely lets me know I'm making the right decision.
Any lift kit installed or factory Rebel set up?
I have Bilstein 6112 on ring 7 up front, 5160 in the rear. Gave me 1-3/4" lift in front and around 1/2" in the rear.
How do you like the 5160’s compared to the stock Rebel shocks?..
I gotta say, if think they're excellent. On road they feel very similar to stock but perhaps you would expect this on a almost completely flat and smooth surface. Off road is where they shine. My driving is almost exclusively desert/sand so lots of bumps and they (6112s & 5160s) just absorb it all up. The stock suspension was being driven close to its limit and was bottoming out quite frequently. I could tell I was hitting the bump stops regularly. I have not had that issue yet with the 6112s amd 5160s. FYI, I do not jump my 2019 Ram Rebel...yet 😁 However, lots of hard landings going over dune crests....they just soak it up. If I would change anything it would be to add adjustment at the rear to stiffen when carrying load...otherwise a great setup!
