I bought a 2019 RAM 1500 in May 2020. I noticed a loud humming noise and vibration two months after purchase. The noise is a pulsating sound so loud its almost deafening, and the doors vibrate. I also have to add this happen intermittingly. Once the truck is turned off it won't happen again for a few weeks. I called different RAM dealers and none of them had heard about it. Finally when it happened again I drove it straight to the dealer and made them test drive it. They agreed the noise is there but they didn't know what was causing it, so they referred it to the field engineer. That was in November 2020
Yesterday I finally get a call back from the dealer. They said that Chrysler sent them a bulletin about this issue and that it is normal. The noise comes from the Noise Cancellation Module and happens intermittingly, and there is nothing they will do about it. Since it's not a safety issue there isn't anything they can do about it.
I have read several threads on here about this issue and nobody has a resolution. If I'd known about it, I would have never bought the truck. I'm now considering getting rid of it, because its to loud when it happens. Hope this helps others with the same issue.
