bucolic
 - Jan 17, 2020
- Location
 - New York Upstate Not the City!
I just traded my 2019 Laramie 5.7 Hemi with 3.21 gears for a 2021 Limited Etourque Hemi with 3.92 gears. Prior to the 2019 Laramie, I had a 2016 Ram Big Horn Hemi with 3.21 gears. I put 81K on the 2016 Big Horn and I put 28K on the 2019 Laramie so I have over 100K miles driving with the 3.21 in a short period of time. I towed a 6000lb trailer this summer with the Laramie 3.21's a total of 8000 miles. I did a cross country trip from NY to CA and back towing the trailer. It was not effortless. I felt under trucked the whole trip. The 3.21's get the camper going no problem at all. The trouble comes in with wind and hills. It could comfortably pull much heavier loads if they did not have the large sail the camper creates. Of course, towing a camper with the light-duty 1/2 ton is not ideal and most people who tow a lot bump up to the 3/4 cummings but I did;t want to deal with a 3/4 ton truck or the diesel. I think the Laramie was rated at 7500 lbs towing capacity where the Limited with the 3.92 is rated at about 11,000 lbs.
Now, I'll touch on the biggest reason I traded. The 26-gallon tank. It was miserable. Range while towing was 250 miles when filled so every 150 miles you needed to start looking for a gas station. Especially in rural areas like Utah and such. On days I did 600 miles I was stopping as much as 4 times to fill up. Range anxiety was like being in an electric car LOL. I needed the 33-gallon tank and decided to get the 3.92 gears as well. At this time I will also mention something I was not aware of and that is that many of the Hemi's with Etourque come with a 23-gallon tank. I just can't even imagine towing with that small a tank so when looking at these trucks be aware of that. Someone correct me if I am wrong. Even for everyday driving, 23 gallons seems absurd on these trucks.
So, back to the 3.92 gears. Having driven over 100k miles with the 3.21's I can say from experience I can feel the difference with the 3.92's. I have yet to tow with it so I can't comment on that yet. But in everyday driving the difference is substantial. The truck shifts faster and going up hills it just goes up them. The 3.21's would shift down into 6th or even 5th without a load on hills and the 3.92's just stayed right there in 7th or 8th gear. It runs at about 1800-1900 RPMs at 65-70 whereas the 3.21's appeared to be right around 1500 RPMs so noticeable difference there. My mileage is way off what others say but the truck only has 600 miles on it so perhaps that will climb. I could get 20-21 mpg with the 3.21's and the 3.92 so far have never been higher than 17. The 3.21's seem to be lugging compared to the 3.92's but the lower RPMs are noticeable on the 3.21's. I can see the benefits of both. I don't expect to see a substantial difference when towing with the 3.92's but I am hoping it's enough to take the edge off in the wind and hills. Overall I think the 3.21's give a nicer casual driving experience. Smooth, low rpm's and not as quick shifting. The 3.92's have snappier, quicker feeling shifts. They also go into eco mode more often at lower speeds than the 3.21's. The 33-gallon tank though is what I am most excited about! I can't stress enough how miserable that small tank was on my trip. I swear I spent more time at gas stations than I did at the campgrounds! If I bought one of these and found out it only had a 23-gallon tank I would have been beside myself.
So looking forward to seeing if the higher gears take the edge off of towing my camper. Even if they don't I am sure I will enjoy the added features of the Limited over the Laramie and the 33-gallon tank.
