ssick92
 - Jul 12, 2020
Hey all,
I've tried doing some searching on this forum and research around the web but can't find an answer to my problem. I replaced my bumper so lost the factory halogen fog lights in that process as they were not compatible with the new bumper. I got 2 Rigid SAE/DOT LED Cubes to use as my new fog lights on my 2020 Bighorn but can't seem to get them to turn on at all. I am trying to utilize the factory fog light switch so got some 9006 to Deutsch DT connectors and am getting the proper voltage at the male end of the Deutsch connector before plugging it into the cubes, but the lights still won't turn on. I've tried the connector both ways in case the polarity is reversed, but no luck. I've also already changed the setting in AlphaOBD for LED fog lights. The new lights only pull 22W each compared to the 55W the factory halogens so overloading the circuit isn't a problem.
Any ideas? Do I need to splice into the relay that came with the cubes in order to get them to work? If so, any chance someone has a wiring diagram for how to do that?
