Any way to turn (all)Headlamps off?
TAK
South West Florida
I have not found a way to turn off all the headlamps off ...unless I shut the engine off. There is a reason for wanting to be in a stealth mode, however its really too long and boring to explain.
It would help if we knew what year, model, trim, etc you have. Please add that to your signature so we can help you.
  • Wow
Reactions: TAK
I’ve been researching the same thing and my conclusion is without the aftermarket tool like the Tazer DT, it is not possible with the stock factory settings.
This used to work on older vehicles but try putting the parking break on just a touch?
I noticed that also. Since my headlights are also my DRL’s you have to go into the settings and turn off the drl, then when you rotate the headlight knob left they will turn off. Not sure how to have both though.
Another thread that discusses this further.
Spoiler alert: No.
  • Like
Reactions: TAK
ok im looking to do the something different i want all on hi,low,fog i know on my gmc sierra i used a jumper wire on the hi & low beam relays with a diode. & all lights would run with out hurting the bcm. has any one done this on a 1500
