Amenadiel_Power Wagon'20
Hello everyone. I have a 2020 Power Wagon and recently hooked up a brush guard with 4 LED pods, 2 A-Pillar LED pods, 2 rear trailer hitch attached LED pods, and wiring for future rock light and roof mounted LED Bar attachments. I have them all connected through the battery, relays, and inline fuses to a 6 switch rocker panel and was wonder how to wire the switches to the Dash light circuit and where that may even be? The switches I'm using are the 5pin, dual indicator LED ones. The top indicator LED comes on by flipping the switch on when using a specific LED pod set (Showing power is correctly being output to it), however from various videos, the bottom indicator light will only illuminate when the truck is turned on (Remains on the entire time the truck is on, regardless of switch position), if wired to the Dash Lights Power Circuit. Where is the easiest area to access this power circuit and easiest method to wiring the switches to it, for anyone that's done similar?
