bhardy5005
- May 26, 2019
I had been noticing an air leak sound coming from the door, right around my ear when driving. Happening on the passenger side as well. Thought the door may not be closed properly or just not a good seal but the strangest thing happened, when I shut the fan off the noise went away (had the heat on). I experimented and found that the noise only happens when I am using outside air mode when the fan is on. If I go to recirculate mode, the noise stops. I can not figure out why this is happening because it hasn't always been this way and it is a distraction. Anyone else having this issue?
