Deployable bed step not part of Bed Utility Group?
AK103
Just noticed on my Limited window sticker, the deployable bed step is not listed in the Bed Utility Group -
I also got the MFT gate, if that makes any difference.
So no step for daddy?!
I believe that was a problem initially as there was no bed step available for the MFT. There are 2 bed steps, 1 for regular tailgate and 1 for the MFT. Try building a Ram with MFT and BUG and see what it shows. BUGs were showing up on people's build without the bed step and members were getting the dealership to throw it in as I believe it was listed for the BUG. Those were pre MFTs.
Hope that helps some.
The BUG is better for some as I believe your build comes with the bed lights and spray in liner. The rails are about 250+ from what I can remember and the bed step is probably about 300 or so.
Nice truck by the way.
My window sticker with BUG, I just figured if you got the BUG then you got all items included with that group but apparently not.
I have a 2021 Limited in transit, the window sticker is like yours, and doest mention the step under the BUG, but it does show up on the build sheet.
Thank you. I hope it's there.
Otherwise I paid for some expensive rails.
It's strange, it showed the step on the site when I built it.
rambox also comes with rails without BUG.
the cargo dividers also seems to be frequently "stolen" too.
That’s not available with the Bed step because it’s a 2020 model, look when it was built: 1-23. The bed step for the MultiFunction Tailgate wasn’t made available until the 21’s came out in Late Summer. As far as the OP’s issue, it’s just the way the window sticker was printed I believe. If you have that special tailgate and the BUG, you get the step, center mounted (aka the new one). The old one, for the normal tailgate (located on the left side) was put on hold for a while for a recall but you can get it too depending on your options. I ordered a ‘21 Limited with the Rambox, BUG, and MFT, and I should get the divider, the step, the lighting, and the spray.
The lighting and spray in are standard on my build due to it being a limited.
Awesome. hope it's there.
Thank you.
Thank you.
Gotcha, yeah with mine being a laramie (without) MFT it must come standard with the BUG. I can't afford one of them there limiteds 😝....wasn't familiar with the build sheet on them.
