Stock 20” rims for off roading/Mopar lift with 3.21
AK11
Have a 2019 1500 crew cab short bed with ORP and 3.21 ratio. Looking to get into some light-medium off roading and was wondering if the 20’s would be fine or if I should get a set of 18’s. Also if I should go with the 18’s, I was reading that a lot of 18” rims don’t fit on the 5th gen’s so was wondering if there is a way to know if a specific set will fit or not before actually buying.
Was also wondering if adding the Mopar lift along with bigger tires would be too much of a strain on the 3.21 ratio.
Thanks!
Having more sidewall is always advisable for offroading, and there are plenty of 18 inch rims that fit... including ones from Ram themselves. Most Rebel owners with aftermarket wheels are still riding on 18's.
You should be fine with the 3.21 rear end, but there might be some performance loss if you do a lift and go with 35's for example.
I went with rebel 18s and 285/70r18. But better ride. Also have a bilstien 5100 level which made it even better.
Where’d you get your wheels? This is the exact setup I’d like
did you notice any change in mpg switching to 18's?
Thanks!
My current setup is 2019 1500 with 20’ and have 285/60R20 KO2s. I didn’t feel like trying to buy wheels yet so I’ve been happy with them. Smaller wheel size is usually better for more “meat” on the tire since you can air down more.
Can you tell me about your hood light set up?
I have baja design XL80 sports with zroadz roof mounting brackets.
-Midnight @midnight_the1500
Laramie 5’ 7” 4x4 Crew Cab
Diamond Black Crystal Pearl
Level 2 Equipment Group
19–Speaker Harman Kardon Premium Sound, Blind–Spot with Cross–Path Detection, HD Radio, Heated Second–Row Seats, ParkSense Front and Rear Park–Assist with Stop Rain–Sensitive Windshield Wipers, Rear Under–Seat Compartment Storage, Remote Tailgate–Release, Rear 60 / 40 Folding Split–Recline Seat Single–Disc Remote CD Player, Tailgate–Ajar Warning Lamp, Uconnect 4C NAV with 12–Inch Display, Front and Rear Rubber Floor Mats, 3.92 Rear Axle Ratio, Anti–Spin Differential Rear Axle, 5.7–Liter V8 HEMI MDS VVT Engine, Panoramic sunroof, Power Running Boards, Rear Wheelhouse–Liners , 33–Gallon Fuel Tank, 20” polished rims, drop in bed liner
Items installed after purchase:
RetraxPro MX Tonneau Cover, Yakima crossbars and Bike rack, Mopar 2” lift kit, Ceramic Coated, Tinted windows, AMP research side step 2.0, Lasfit Auto lighting for third brake light, K&N drop in air and cabin filter, Suspension and Transfer Case skid plates, 285/65R20 BF Goodrich KO2s, Wilco offset hitchgate.
