2019 Limited V8 Hemi - Fuel Filter Location?
hamburgram
I have a 2019 RAM 1500 Limited with the V8 Hemi gas motor. Where is the fuel filter located and how often does it need to be replaced? I cannot seem to locate any info on it. Thanks
Dusty1948
Rochester, New York
Looking at the DT service manual, the only reference I see to a fuel filter is integral to the fuel pump module itself, which is inside the fuel tank, and very typical of fuel system design nowadays. I think you'll find there is no routinely serviceable fuel filter used in the Ram 1500.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044446 miles.
Jako
Borough of Parks
Best regards,
Dusty
Nothing like my 1985 Toyota Corolla that had it on the fire wall. I knew when to replace it when I stepped on the gas and got hesitation, let off the gas pedal and it ran OK. The simple good old days.
Jsavoie
Best regards,
Dusty
Correct, no external fuel filter on rams
Dusty1948
Rochester, New York
Yes, my '03 Dakota had a fuel filter mounted on the frame rail.
A couple of techs have told me that the sock filters used in todays fuel pumps are actually better at filtration, and they say they've never replaced a pump because the filter was clogged. The pumps fail before that happens.
Best regards,
Dusty
James Fay
Why does Mopar keep telling me to replace my fuel filter if it is not serviceable? Screenshot_20210730-065355_Email.jpg
