Hellwig sway bar making noise
U
User_21361
Guest
Ive noticed a few times now that after water crossings or muddy off-roading or trip to the car wash that the rubber bushing on the hellwig squeaks like crazy. The last time it happened, I took it off and greased the bar. It fixed it right up but was a PITA and not something I want to do every couple of months. I searched and it doesn’t seem anyone else has this issue. Any thoughts or remedies outside taking it off?
vincentw56
That's very typical for urethane bushings. Some other suspension items use greasable fittings that eliminate this or at least make it less.
U
User_21361
Guest
Yeah, I have grease fittings on almost everything else. Does anyone know if one works with the hellwig?
PorBoy
Millville NJ
I couldn’t find one to work with mine so greasing I will go. :(
U
User_21361
Guest
If I can find a drill press, I may try to add a zerk fitting to the mounts. I’ll report back if I can make any progress. The squeak is really bugging me haha
U
User_21361
Guest
Have a tap kit and zerk fittings arriving Friday. It won’t be prefect but hopefully easier than taking the darn thing apart every few months. I’ll post back on progress when I make time to install
U
User_21361
Guest
I did one side. Not extremely happy with the results. The grease mostly shoots out of the side of the bracket instead of the bushing. The question is how much grease is making it to the inside of the bushing. I’m going to leave one side normal and test to see if it is actually any better over time. The install took about 10 min
BmoreStew
Another option is a couple wraps of thread seal tape around the sway bar. The stuff for water fittings is good, the tape for gas fittings is even thicker. Wrapped mine 18 months or so ago and it’s still working today.
U
User_21361
Guest
Sweet, ill have to give this a try if my grease method doesnt work. Thanks for the info. Do you do a lot of offroading or water crossings? I have noticed mine gets way worse when it gets gunked up.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
I have this problem too! It’s annoying but I don’t care too much
Scram1500
I wonder if graphite powder would work too. The teflon tape idea is genius
BmoreStew
Nah. No real off-roading, just “truck stuff” around the property. It started squeaking on mine really early on, it’s been a long while, but I wanna say within days of the install. Wrapped it with tape (someone here had suggested it) and it’s been silent for the past 18 months or so.
o
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Around which part of the sway bar specifically? Around the bushings?
Jako
Borough of Parks
Hellwig comes with grease. Do you know if it was greased when installed?
I have used this grease below on the splines on BMW motorcycles, pricey but really good stuff.
Not sure how either would work in your application but can verify the staburgas sticks.
U
User_21361
Guest
I did grease it when I installed it and a few times since then. The issues is more when the under side of the truck gets very wet or gunked up, the noise starts again and needs more grease. Im going to run my current setup for a few months (since I already drilled everything haha). If that doesn't hold up, ill replace the bushings and try out the teflon tape. If I could get 18 months of use with no noise as others have seen, that would work. Right now I've been having to grease every 2-3 months which is too much work.
