Recon LED Headlights
Bruins5515
Has anyone installed Recon LED headlights like the ones below, they are doing 30% off for cyber Monday and i want to order but want some opinions first.
I haven’t installed these specifically but I can tell you from numerous other purchases from recon that they make quality products. I would recommend their products any day...
I just ordered those and then tails, couldn’t beat the 30% off. Hopefully will be here soon.
I ended up ordering as well, shipped same day, mine arrive Thursday, hoping to install Saturday !!
Hopefully mine come Friday, plan to do the same. Let me know how it goes 👍🏻
Nice looking headlights and taillights. I think you guys are going to be happy
On a side note when are these part suppliers going to realize it's not a Dodge
20811B10-4735-4F9F-93E3-3F17EEA32947.jpeg Got them installed. Unfortunately passenger side turn signal isn’t working & my tail lights never shipped yet. Definitely loving the looks of these though & the figment is great
Were you able to wire the DRL's?
I talked to recon this morning as i just installed mine, the DRL are wired to only turn on with headlights which doesn’t make sense to me so they are sending me the wiring diagram and told me i could tap fuse the wire for DRL to come on with ignition. Not sure if i am going to do it yet.
I was considering the Recon headlights if you could run the DRL's without the headlights and they dim when you have the headlights on. :rolleyes:
But I have not seen anyone with this configuration. :unsure:
Thanks for posting. (y)
They are brighter than the stock accent lights. :cool:
Did you go with LaminX on the fogs or Lasfit yellow LED's?
Those are the switchback from lasfit. I am 50/50 with them. They tend to unsync and are different colors.
I think I will go with the LaminX yellow film then.
Were you able to fix your passenger side turn signal?
I verified with the old headlight that the turn signal worked. I checked the pins on the factory connecter and made sure it had 12v when the turn signal was activated and it did. Then i hooked up a 12v battery to the recon turn signal and it wasn’t working. I contacted them and haven’t heard back yet.
Try and reverse your polarity connection on the turn signal. Recon may have installed the LED the wrong way. LEDs are polarity sensitive.
I am about to pull the trigger on these as well, but I wanted to make sure the beam pattern and output are good. AI'm planning to get the full LED version as well. any feed back about general quality and actual night driving with these would be great. thanks
They fit real nice both headlight and taillights. The taillights are nice and bright & the headlights are like the factory led output.
All i need to do is tint the 3rd brake light to match them
