MTaylor1978
 - Nov 25, 2019
Here are the snowflake rims on the Limited. My mechanic sent me the picture, so I'll post some better ones later in case anyone is interested in doing this. Tire size is 305/45/22I'm having 22" chrome "snowflake" rims put on my 19 Limited tomorrow. We did a test with one of the rims and it seemed to fit and clear just fine. My 22" stock rims and tires were stolen last week necessitating the new wheels
I know this thread is over a year old, but those 305/45/22's seem to make the wheels stick out a little more OR do you have wheel spacers on? The original 285/45/22 seem like they are tucked inside the fender wells because of the fender flares... I like how your wheels/tires look like they are more flush with the fender flares.. I'm looking at Chevy Honeycomb wheels for my ram and know the offset if different so I'm just now looking and researching.More pics
Great news. I have some GM reps picked out I loved on my last truck and I think they would look great on my Ram.No ring is needed. The clamp force/friction from tightened tapered lugnuts is what holds them at the face. They are "lugcentric". Many lower cost wheels have a huge bore to fit all makes and don't use rings. Rings that may be included with high end wheels are to help you hold it in place until the taper of the lugnut engages. I find the stud to wheel hole clearance does this easily.
Someone will be along shortly to say they're uncle's mother's cousin's hairdresser said nutuh, u gotsta hav 'em.
Thanks! I'll keep that in mind and make sure my sequence is right.You just need to do the proper sequence of lug tightening and there won’t be an issue.
Almost all aftermarket wheels don’t come with the hub centric rings. And the ones that do are plastic and are just a guide to make sure the wheel is perfectly centered.
Will do! I'm dig up this thread when I get them. I'm going to run the OEMs through the truck's first winter for the sake of the salt. It isn't too bad in KY but I'm a clean freak.Post some pics when you get them.
I’m runnning hostiles from my Chevy currently. But I think I may go to snowflake gm reps
