I took my truck into the dealer on May 28 to deal with the Uconnect rebooting periodically and draining the battery overnight.   They diagnosed it, and determined the radio was drawing excessive amps.  It's going to be closing in on a month with no truck waiting for a replacement radio to show up.   Is anyone else seeing these issues?
When I would charge it prior to starting it would pull high pull a high amp load on the charger for an extended period where typically a dead battery would start out higher and amperage will taper down as the battery charged. This one would taper down some but was still pulling pretty high amps after several hours on the charger.
