bill-e
So my 2020 absolutely sounds more like a diesel truck than my 2015 did. Anyone know if the sound deadening foam on the engine has been removes or reduced?
I hear more of the pinging sound.No I think it's been increased. I found inserts on each side of the fender. I don't know if it sounds louder compared to my 2018 but I can certainly hear the turbo a lot more.
I often drive with the music off and I'm deep in thought so I hear all the sounds the truck makes.
My '15 had very little diesel sound but even when in 2 wheel drive I could always here the grinding of the clutches. My '20 is significantly louder from a pinging perspective but I haven't heard any of the clutch sounds yet. I don't hear the turbo in either, perhaps that sound is in one of my old age deafness ranges
I removed the engine cover, removed all the foam sound insulation, removed the snorkel between the air box and the grille, and replaced the intake pipe from the air box to the turbo with the T&S Speed Shop aluminum pipe. On a cold morning she sounds like a piece of construction equipment now. I love it. If I keep this truck long term the exhaust system is the next thing to go.
The hood etc is the same as the Gen 4 truck. The engine cover is smaller but personally I think it's the tune causing more ping when cold.I think it's the aluminum parts now like the aluminum hood. It is unmistakable a diesel. Nothing like a TDi where you could dismiss it as a loud gasser.
Wouldn't mind hearing that noise just for comparison.
