ArtieD
Bit the Bullet and did a 6" lift . Ride quality is just as good as stock ,
at least with this lift setup which has a preload spacer ,I may upgrade to fox But the ride is awesome so if you were worried about ride quality ,(Like I was !) , No worries it is just as good , there is a little driving adjustment but after 2 - 12hr non stop rides , I recommend doing it if your on the fence about ruining your ride.
I can still drive with a full cup of coffee in the center console and not spill a drop ! , My 17 silverado LTZ could not do that !! its straight up 6" non aggressive with 37s the shop usaully use 2" spacers on the wheel with this setup, but I think this is a clean look and what I wanted Just wanted to share That Cheers ,
Also unless your racing your truck at the track with the 3:21 w/37s there is very little power loss , it is hard to not spin the tires at the light if you jump on it a little and at highway speeds it drops to 5th where it was happy in 6th when you need to pass , but it is not really noticeable at all , the truck is a beast and I am Glad I bought the ram
