2019 Limited with Air - Biggest tire with and without trim
accupulse1
New here. Howdy. I've been several layers deep in this forum trying to get a definitive answer to the "largest tire" question. I'm hoping someone can help finish the discussion for 2019 Limited with air suspension.
Current stock tire is 275/55R20 on the stock 20" rim. I would love to replace both with a more aggressive looking tire. However, I have gotten used to the luxurious ride of my new Limited and don't want to screw that up. I'm ok with a little noise and would prefer not to trim if I didn't have to but would do it for the right tire. I don't want to pay $3k for a lift. Just looking for something a little taller and meaner looking but still offers a smooth ride. 4x4. Thnx
ammdrew
We put 25k on these before swapping truck. touched the inner fender liner on the edge of it at full turn, I just bent the plastic back a little(very thin and easy to bend and move).
Putting 275/65r20's on the new eco tomorrow. Trying to balance mileage and ability a bit but the eco is geared much better with the 3.96's.
accupulse1
I have 295/60/r20s being installed tomorrow with 20x9 rims. The shop has 305/55/r20s to try as well if these don't work. Both Toyo AT tires. Thanks for the info.
Any else?
ammdrew
275 65r20 34 inch tire no lift, no level, no rub...
accupulse1
Here's the updated pics. The 290/60s are perfect at all levels.
iLikeTurtles
275/60r20s are around 221 per tire for falken wildpeak at3w.
When i jumped to 285/60r20s they were all 10 ply and $340/tire.
The extra half inch wasnt worth almost another $500 for just tires with a rougher ride.
May be worth it for others. Depends on if you dont mind waiting for deals or buying lower mileage and rating tires.
accupulse1
I don't mind the 10 ply tires. I don't notice a huge difference in ride or performance. I like the extra height stance because I don't plan on ever paying $3500 for a lift kit for the air ride system.
iLikeTurtles
Then spend the money on daystar spacers and revel links for the 34.5" tire.
frostymug
No rubbing at any level or turning radius.
Thank you. Are you in Canada? 290 isn’t a common size.
And just to be sure, does your truck have the standard air suspension or is it the off-road version?
cdn.tbird
290 isn't a common size in Canada either.
Sdnyc82
What offset on those 20x9's?
