anyone put the rebel rim on a Limited?
NorthernArea51
NY
I want these rims! I’ve been searching and can’t find them. Any ideas?
I’d keep my eye on the buy/sell section here. eBay always seems to have a few sets too depending on how much money you want to send. I found my set on letgo when that app was still around.
EStein
Battle Ground, Washington
Cool. I can’t even figure out what rims they are though? Are they a Rebel rim? Smoke?
Thanks
NorthernArea51
NY
Thanks
I think those ones are the blacked out rebel rims. You’ll see more of the two toned rebel rims out there I think than those ones.
EStein
OK thanks. Yeah eBay has a bunch of the two-tone ones. The ones posted earlier looked more of a smoke color than the black package. Might just be the photo... either way I like them better than my standard Big Horn rims.
NorthernArea51
NY
They’re basically the same rim. Just toned differently. But I agree...i was looking for months for rims I like enough to buy and then I stumbled upon this place and saw all the rebel wheels being on non-rebels and ears perked right up lol
antwon412
I have 2 sets - all the way in Northern California though.
the 2 tone - wheels only
All black with tires mounted on wheels
RAM Patriot
Clayton GA
Just put Rebel rims and tires on my four-corner air Limited today... No rubbing at all. Slightly worse mpg, but the ride is still excellent, even with 50psi. I might try 60psi.
The following is the recommended tire pressure for the Rebel Tires.
Goodyear Duratrac.
Rebel Tire Pressure
Front: 55 PSI
Rear: 45 PSI
Alex5737
outdoorco75
Goodyear Duratrac.
Rebel Tire Pressure
Front: 55 PSI
Rear: 45 PSI
Where did you get those pressure settings from? My Rebel with Duratracs came set at 60 front and rear from dealer.
antwon412
Listed on the door jamb of our Rebels.
Mine came over inflated as well. Dealers are idiots.
SD Rebel
San Diego, CA
60 psi is the dealership lot settings to prevent tires from flat spotting for trucks sitting on the lot. They always forget to adjust them down to the correct level before delivery.
As Antwon412 stated, the door jam sticker shows the recommended psi which is 55F / 45R.
outdoorco75
Great. I was thinking it felt a little jarring.
SD Rebel
San Diego, CA
I lowered my fronts to 50. A noticeable difference, much less jarring
Similar, I do 51 F / 41 R cold pressure, rides a bit better and still good buffer before the low pressure warning would come on.
Alex5737
Oh man. Why does this have to be so difficult. I like keeping things stock but I also like nice things. So I'm stuck between being reasonable and spending less cash or going all out and spending more 🤷🏻‍♂️. So what do u all think I should do....stock Rebel wheels or Bronze/Black 701 method wheel.
NorthernArea51
NY
Oh man. Why does this have to be so difficult. I like keeping things stock but I also like nice things. So I'm stuck between being reasonable and spending less cash or going all out and spending more . So what do u all think I should do....stick Rebel wheels or Bronze/Black 701 method wheel.
I’m a sucker for the rebel wheels
First ones I’ve seen on an all white model too...looks sharp and tough without looking like you’re trying too hard
NorthernArea51
NY
Oh man. Why does this have to be so difficult. I like keeping things stock but I also like nice things. So I'm stuck between being reasonable and spending less cash or going all out and spending more . So what do u all think I should do....stock Rebel wheels or Bronze/Black 701 method wheel.
Also...what drop steps are those?
