Kevinch
2020 Laramie Sport: is it possible to have the factory fogs programmed to turn on whenever I want them to be - headlights off, or hi-beams on - as opposed to only when the headlight low beams are on?
When I bought my Harley dresser, the factory passing lamps were set up to shut off when the high beam was switched on. It took the dealer to change the programming, but now when the passing lamp switch is activated the lamps are on regardless of the headlight condition. I'm wondering if the fog lights on my RAM can be set up the same?
