Seadoorxpguy
- Nov 24, 2020
Here’s the manufacture specs on my camper
So basically if you buy a Dodge Ram and have 3 friends (225lbs x4 ) in the truck with you, you cant even haul a yeti cooler full of beer in the bed or your going to be over payload capacity.
What exactly was “sketchy”? That would help inform some suggestions...So I just picked up my new 2021 ram Laramie ccsb 5.7 e torque with every option except air ride ( it was on the lot and checked all the boxes for the price) Tried towing my 32` keystone cougar last night and boy was it kinda sketchy even with a wd hitch. The camper is 8300 lbs with 1100 lbs of tongue weight. Told the dealer exactly what I had for a camper and he said it wouldn't be a issue. Now im thinking I should have done a little more research on the truck. I just ordered the helper bags. Any help would be appreciated
FCAs towing lookup by vin is so wrong for so many trucks. Use the door jamb.Another way to see what your truck is rated at, is to go to this web site and put in your vin number. Then deduct all the added weights you pull or load, including people, trailer tongue weight and anything else you tow or haul. You might be surprised at what you find out. - www.ramtrucks.com/towing-guide.htm then click on towing capability then towing guide then look up my vehicle. That's where you enter your Vin.
