Tow hook Shackle Swap
Apettit13
Has anyone come across, or rigged up how to swap the front row hooks to shackles?
move got a shackle on the rear hitch, and I would love to swap the front row hooks over to shackles in order to match, but I cannot seem to find anything.
If anyone has done anything like this, please post some pictures and let me know where you found the items!
Sorry but I don't follow what you are looking for. The tow hooks bolt to the frame. Can't picture a way to attach a shackle in place of the tow hook. Are you wanting an eyelet in place of the tow hook? Basically a plate with a hole in it allowing you to connect a shackle to the plate?
Sent from my SM-T230NU using Tapatalk
What I want is something like this. Obviously the tow loop wraps under and bolts to the flame, I essentially want something that replaces the look with a plate to put a shackle. Haven’t been able to find anything, and not sure if anyone else had something that existed.
You could always try something like this Shackle might take some drilling
That’s for an actual hitch, it would be too thick for the bezel, I also don’t think it would be long enough. On top of that I would like to refrain from drilling into the frame lol
Ok, that's what I thought you were getting at. I've not seen any for our body style. Thinking something turned 90 degrees might fit through the bumper openings but I like the idea. I don't have factory tow hooks so if you find something share it please.
Wow...I was just googling something like this...then I came to the forums to search as well and found this thread.
I don't have any tow hooks on my laramie, so I'm trying to figure out what I can do. I don't want to get the factory front hooks because they aren't open for me to slide my strap on easy.
I was lucky enough to get stuck head first into a small ditch and I was able to use a shackle tied to my tow hitch to get pulled out by my wife jeep ( she has an aftermarket bumper with shackles) ...and worked like a charm. Now I need something in the front.
Owner of a 2020 Ram Laramie, 16 Dodge Charger scat pack and my wife 21 Jeep Wrangler Unlimited Sahara
I'm planning on getting the tow hooks and picking up a soft shackle. Loop shackle onto hook and through strap, problem solved.
Well d@mn. Didn't think they made soft ones like that. Then thats what I will do. Now I need to get my tow hooks. Thanks.
