Anybody on here running a -51 offset. Looking at getting a pair of 22x12 -51 Offset Wheels on 33x12.5 Tires. Just wanted to see a picture of a setup with this offset to see if this would be a ridiculous look or if it would look okay.
What do you mean by ridiculous? If you mean nearly half your tire outside of the wheel well then yes it will look ridiculous.
take a look at this. might give some ideaIs that about how much will be outside? I was thinking it would only be about 2 - 2.5”. If its gonna b close to 6” then no shot in hell im gonna get them then.
I think I can confidently say you’d be more than 2-2.5 inches. A -51 would be a huge offset. This truck is a -76. So compare this and the post above and that’s about what you’ll get.Is that about how much will be outside? I was thinking it would only be about 2 - 2.5”. If its gonna b close to 6” then no shot in hell im gonna get them then.
You also have to add in some extra width of the tire if they are going with a wider wheel/tire package.-51 is only 7mm further out...if I'm not mistaken 24.3mm equals 1 inch...so -51 would be about 2" out from 0 offset
What is your stock tire size?Im going to go with a 22x12 wheel. 33x12.5R22 Tire. How much wider do you think this will be?
