Air Suspension and Lowering the Rear?
2020SilverMidnight
I am only thinking about trading my BigHorn for a Limited. But before I do I need to know is there a way to lower the rear the 2" to level the truck while in normal ride height mode? That would give a true 2/4 drop in entry/exit mode, which I am perfectly fine with. This is the only way I will get a truck with air suspension, because I am not a fan of the rake and I don't want to lift the front. Not a fan of that either.
The rear is easy to adjust. Either make a set of links or buy a set of rear drop links. Shorter=lower
Is there a company making the shorter links? My searches have come up empty, that's why I was curious if you guys knew of any?
I thought air suspension came level as it is. As it will air up the rear bags to level if there is a load back there. So no need for a rake. But that’s just my thought.
The normal driving mode is not level, it has the rake in the rear like a coil spring truck. If there is a load, maybe, but not in the bed is empty.
That’s stupid. Why do they do that on an air ride? For some reason I thought it was level. That’s first thing I’d fix then. Hate the rake
^^^ This ^^^
Here’s mine for reference. It has a slight rake, but not too bad.
So I talked to Revel and they said with their lowering links they can get the truck to stay in entry/exit mode? Can anyone confirm this? Does anyone have this done to theirs? If so, I would be curious to see it and hear how well you like their kit.
There's a auction on ebay that shows before and after but I believe you have to modify bump stops. I can't tell if the pics are with it in entry mode or normal? Anyone done this mod?
So after looking it over you would have to modify the bump stops in the rear of these trucks if you were to ride in entry/exit mode
Assuming if it’s even possible to ride around in e/e it won’t be very comfortable either as the bags will be under inflated.
According to Revel, the rods change the voltage to read the vehicle is lowered, thus keeping air in the bags. So it shouldn't change the ride comfortability if I am reading it right.
Has no one done this on this forum? There is a silver one on their website that has been dropped. Looks great
Yeah it does! I am curious if anyone has done it also. I would love some real world feedback.
Maybe i should just give them a call. I'm an old mini truck guy so this is right up my alley if it doesn't ride terrible.
I'm thinking of doing this. I have the links and was planning to lift to level, as everyone on this forum seems to do, but I really just want level, and tires that fill the wheel wells, not necessarily big wheels.
I think I just put in in tire jack mode and do it, and my links should be adjustable.
Lift the front (spacers and links) and ride around in aero.
Lowering the rear that much will make it feel like you just had a fist used on you for a prostate exam. Which is fine if thats what you are into.
