Max tire size on 18in stock wheels and off road package.
notilloc
I have been searching for hours and I can't find an answer on this. My truck came with the 32in falkens and they're pretty worn out and it's time for new tires. I would assume I can fit 33in tires (275/70/18) but can I go bigger without a level? I tow too often to get a leveling kit but I'd also like to stuff as big of a tire as possible without rubbing. Has anyone tried to fit a 34 (295/70/18) on a stock off-road package?
I haven't installed my 33's yet but I have stock suspension and from my research on here they should be fine. ORG adds a 1" Lift so my assumption is you can go 34's. I will be adding a 2" level probably around the same time I swap out the wheels so that makes a difference but as far as 33's go I believe you're fine. 35's may be a stretch but I have seen some guys here run that with small modifications (heat gun/zip ties).
i have the rebel wheels on my org ram and its fine, no lift . i think they are about32.4
I saw this one but he has air and I have standard coils. Figured that would cause differences.
Thanks, I'm not woried about 33s at all but I'd love to be able to squeeze in a 295/70/18 or even better 285/75/18 and I'm hoping someone has tried it on an off road
I typo'd 33's instead of 34 when I said "I believe you're fine". What I meant by my post was, if I can do 33's no problem stock, you should be able to do 34's (because your factory 1" lift). But like I said 35's would be tight or not possible at all.
I have not seen anyone with stock ORG run 35's. The ones that do, have 2" level.
EDIT: Found this. Looks like it can be done. Hope that helps.
