What psi for my tires?
jeffrey5679
I put on some pirelli scorpion plus 275/60r20’s and I’m not sure what pressure to fill my tires to? Door says 36 but that’s for stock tires. The max pressure on the tire is 44. I know there’s a bunch of factors but anyone have a pressure for daily driving?
I’d set it to 36 psi like the door sticker says , if you change to AT tires then you might use a different psi but as long as they’re still P rated you should be good .
Start at the door pressure and after a couple thousand miles measure the wear across the tires in each gap. If the shoulders are wearing more, up the pressure. If the middle is wearing more lower it. When it is even, the pressure is right.
The new tires are A/T tires.
