Wheel Offset for 275/60r20
ExileActual
I have a 2020 big horn night edition and I don't want or need a 10 ply tire. I want to get a set of 275/60r20 AT tires and a wheel with an offset that would put me flush with or a little past the fenders. I don't want to level or lift the truck and I'd rather not deal with any rubbing. Anybody have 0 offset or +10 with 275/60s? Any help is appreciated.
I don’t but I do know that is what you’ll need if you want to be about flush. I used 3/8” wheel spacers with my factory 20” wheels and that size tire and I was right about flush
Any issues with the spacers? I had a bad experience using spacers on my last car. Got bad vibrations at highway speeds and they were good hub centric spacers.
Non at all. I bought some nice ones made by Baer Inc. 3/8” was the thickest I could go without needing longer wheel studs so I gave them a try and they gave me exactly what I was looking for. Here is the best picture I could find. It’s factory black 20’s with the 3/8” spacer and 275/60/20 Pathfinder A/T tires
I'm running 0mm offset wheels, 20x9 in size, and 295/60 tires. It's perfectly flush with the fenders. I ended up putting on the Bushwacker OE style thin fender flares and now the wheels are just a hair tucked back into the wheel arch again. Looks about perfect.
Anything into the negative numbers with offset will put you outside the fenders.
I ha
I have 275/60/20 on my 2020 Laramie sport. + 1 offset on my Fuel wheels puts tire even with out side edge of fender flare.
I added 275/60r20 tires and 1.5” spacers. I love the look and have had 0 issues with spacers. This offset would be equivalent to about -19 or -20.
Got any pictures? Surprised that 0 offset would get you flush. Thought it'd put you at least a quarter inch outside the fenders, especially running 295s.
Wow this looks so good! Any pictures from the side please?
Im running a +1 and its flush with the OEM fender flares. It sticks out a bit but due to the side wall bulge on 35x12.5
I added after market wheel with a 0 offset. Pushed the wheels out about 3/4 of a inch and now they line up perfectly with the OEM side steps. perfect to me. The 18/19 stock offset was too far in for me. Especially in the front.; made the tires look totally inadequate.
275/60 R20 on +1 offset.
Sent from my Pixel 4 XL using Tapatalk
Very nice! Do you have a level or is the rear dropped? And what tires are those? Love the look
Thanks. Pirelli scorpion at+ stock suspension. It's a little higher in the rear.
