Suspension Opinions needed
GoRamGo
California
Hello I have been reading a lot about suspension through this forum and am going to finally be getting my items installed in two weeks I would like to just get opinions from people with similar builds on the best way to go about lifting and netting around 3 inches I have a crew cab 1500 non orp. Items that I have right now waiting for installation are as follow front and rear billstein 5100s, icon rear springs and mopar ucas I appreciate any info and or input
I have all of the same parts going on tomorrow morning. Bilsteins will be set to #5. Keeping stock wheels and upgrading to 35x12.5 KO2s. My truck is a non ORP big horn. Ill post pictures and thoughts on it tomorrow after i pick it up.
Don’t think you’ll need the UCA’s
Perfect I appreciate it cant wait to see
From what i have been reading i believe you are right but like some others have been saying for the added security for under $100 i just bought them
Add the OPR springs setting 5 on bilstein will get you 3in. I did do 2in spacer rear. Stock tires 275x65x18
Are the ORP springs for the front sorry im new to trucks and all that as of right now i have 33s on a 20 inch rim
Yes add the OPR springs to the front. That will give you another 1in. So bilstein setting 5 with the opr springs should get you 3in . That's what I did
The ride is definitely stiffer but I don't mind it. To me feels like how a truck should. For now I also kept my stocked wheels. I got around 3 1/4 front bc I have a V6. 20201014_171103.jpg
Just picked up my truck from install. Looks amazing, rides nice just a bit little stiffer. So I had the bilsteins installed at position 5 in front, mopar 2" kit UCAs, bilsteins in rear with icon 1.5" springs. Tires are BF Goodrich KO2s 35x12.5x20
measurements:
stock suspension and tires
FRONT: 21.25" from center of hub to middle of fender
REAR: 23.25" from denter of hub to middle of fender
W/ Bilsteins and new tires
FRONT: 23" From center of hub to middle of fender
REAR: 24.75" from center of hub to middle of fender
Does not appear to be any rubbing, granted i have only driven about 2 miles since picking it up. Will update as i put some more miles on her.
measurements:
I love it looks good yes keep me updated i get mine installed next Saturday
measurements:
We’re the UCA’s needed?.. anything said by the shop?
I will have to try and upload photos tomorrow but so I got mine done looks perfect like what I wanted and honestly to me rides smoother I ended up doing my kit with billsteins front and rear motofab 2 inch top hat spacer 1.5 inch rear icon springs and the mopar lift kit UCAS all together I netted about 3.4 inches in the front and 1.5 in the back
So I have been working alot have not been able to get good pictures but here is the only one I got at the moment my tires are 33s
