Alpharex Nova series issue
Tbltexan12
So I installed the Alpharex Nova series headlights about 6 months ago and haven’t had any issues until the past few days. The low beams on the drivers side flicker and eventually are off with the light switch turned to auto/on. The high beams work perfect, it seems it’s the low beams that are the issue. I’m not sure if it’s a fuse or just a bulb issue. Help please!
KP_98
What bulbs are you running? That would be my first guess
Lights Out
Having similar issue.. Installed in August with no issues. now during the daytime (Alpha Rex Nova) only works on one side of the truck during the daytime.. disabled DRL and when i manually put lights on during day, same issue. luckily they work at night as a pair. for a pair of 1250 of headlights i expect them to work as advertised.. if anyone has any suggestions i'd appreciate it.
Betohemi661
Yes i also had the alpharex headlights same exact issue driver side wouldn’t work but what I did notice is the lights actually worked when I didn’t have the drl harness installed because they forgot it. The only thing is that the drls wouldn’t be as bright during the day but they worked perfectly. As soon as I received and installed the harness I developed the same issue except my low beam never came back on. So i just switched to the morimoto headlights and good luck getting a response from alpharex
