Anyone jnow why they switched from tow hooks to loops?
millerbjm
St. Paul, MN
My 4th gen had tow hooks up front that you could stick the loop of a recovery strap around without a shackle. My 5th gen has closed loop tow hardware - I assume this would require the addition of a shackle in a recovery. Any thoughts why they made the change?
Vilas15
Yes you'll need a shackle. Ill state the obvious and say dont attach a strap with a hook to it.
The loop has got to be stonger than a regular hook right? But if a hook worked for the previous gen then im not sure.
Bassinb
Wisconsin
I am not aware of the obvious here, so forgive me. What would be the problem with hooking a strap with a hook into the recovery loop?
Vilas15
If you use a strap with a metal hook on the end for recovery and it comes loose or breaks, the hook becomes a projectile launching straight at the other vehicle. Recovery straps should have loops at the end and attach to a shackle/D ring or open tow hook on the vehicle.
millerbjm
St. Paul, MN
I did understand the issue with hooks - have a proper recovery strap with the loops and have heard people say they put one end of the strap through the tow hook and thread the other end of the strap through but I figure this would pull very tight and could be tough to remove. I already bought a hitch shackle for pulling someone else out but sounds like I should have another shackle or 2 for the front end in case I'm stuck!
Vilas15
Sounds right to me, I wouldn't loop it because you might end up needing to cut it off. Ive got to get myself the tow loops first then get a shackle.
Bassinb
Wisconsin
Ahh ok, makes sense.
I have looped the strap on itself before and ended up having to cut the strap because it pulled so tight. I guess I should have a couple shackles on hand just in case. They are probably much easier to use when its 10 degrees and everything is covered in ice and snow too.
gsxrdoug
Honolulu, Hawaii
Shackles are cheap!!!! you can buy several. or you can buy soft shackles if your worried about metal on metal.
millerbjm
St. Paul, MN
I didn't have the tow loops on my truck so I bought and installed them a few months back and as the snow started falling here a few weeks ago it got me thinking about recovery situations and being prepared. I like to be the guy who always has the right tool in his truck!
magic280z
Watch Matt's off road recovery on YouTube. Get a kenetic energy rope and soft shackles for hooking to loops. He puts the Yabkum ropes through some torture. Having a short tow strap can be useful too depending on vehicles involved.
2019 Ram 1500 Laramie 4x4 - Crew Cab/5.7 Bed - 5.7 Hemi - 3.92 - Anti Spin - Level 1 Options - RamBox - BUG
