My ItFitsMe video I filmed with ProClip dropped today. The video gave me the opportunity to talk about the “why” behind my channel.
For those of you that watch my channel, thank you so much! You all helped open this door for me and I’m super grateful for that!
I see you sold the Roadmaster sway bar. Did you replace it with something else or go back to stock?
Went back to stock because I wasn’t totally in love with my spacers. In order to clear my diff cover I needed to add 1” spacers to push the sway bar out. The spacers I made worked but I don’t want to run them long term. Sold it to make way for more projects in my channel.
@TheGoogleNinja thanks!
I am super happy with them. The LP4s put out a ton of light. I did the spot/driver combo. I really went back and forth on these over the LP6s because they have a high and low beam. But...love the size of these. Still substantial with a ton of light without being overkill. I have driven around with them some already and they are pretty freaking bright.
That's great. I'm hoping to do something similar myself.
Installed a tailgate assist damper. Side note, you do not have to remove the driver side brake light to install. There is enough room to reach up and attach it from underneath the truck
Hello Trippi, sorry about the delay. I recall that my 2017 Ram had a factory spray in liner and there was some daylight, but nothing too noticeable. The gap also helped with water drainage. Not sure about your model year. Maybe pointing out to dealer or comparing to others would work.
I have this gap as well I believe it’s normal
Working on removing all decals from my newly purchased ram. This includes, the “Laramie” “4x4” and “Ram” on the sides. Obviously I remove the dealer crap off first.
Will upload pics when I’m done
Pass owner of a 12 Ram 1500, Current owner of a 16 Dodge Charger scat pack and 21 Jeep Wrangler Unlimited Sahara
thanks for the reply and sharing your experience. You make a good point with drainage help and to be honest most people probably wouldn't even notice it. I probably overanalyze and notice most things that might not matter. LOL! I am going to add a bed rug that should do it.
Funny how after you buy from them they want you to advertise for them too.
Installed a 6" Zone suspension lift with upgraded control arms and fox shocks. Also put on 18x9 Bronze Fuel Shok wheels with - 12 offset wrapped in Nitto Ridge Grappler 35x12.5.
Oh damn. That looks great. I'm 5-6...so I think that going 6" for me is too high...especially since I don't have side steps. Its wierd how not having side steps makes it look taller.
Owner of a 20 Ram Laramie, 16 Dodge Charger scat pack and my wife 21 Jeep Wrangler Unlimited Sahara
Question for all. Picked up my laramie Tuesday. My short bed doesn't have the spray on liner. But I noticed a bunch of holes on the sides. Im going to guess that its for the bed utility group that isn't on my sticker. Can some of you, without the bed utility group ( that is without the bed rails) show me some bed pics, to see if its the same for all of us?
  • WFO2
