Leveling kit on 4x2 truck
Mi10
I was wondering if anyone had any experience with installing a leveling kit on a 2019 4x2 truck and what kit to use. Thanks
ksn240
The suspension setup is the exact same for 2wd and 4wd models so any of the available ones will work. I went with the Readylift kit with new upper control arms.
Thatwhite5.7
Prosper, Texas
Correct. The strut assembly is the same regardless. There seems to be some misinformation out there so some people may say otherwise. Anything that says it fits a 2019 4wd will fit a 2019 2wd.
So, let me ask you this now. There was a user on here that installed a 2.5in motofab leveling kit from a 4th gen on his 2019 4wd 5th gen. Would that 4th gen 4wd leveling kit work on the 2019 2wd 5th gen Truck.
ksn240
Correct. The 4th gen 2wd and 4wd had different setups. The new 2019 model 2wd and 4wd is the same setup as the 4th gen 4wd models. That 2.5" 4th gen 4wd kit will work on ANY 2019 non air ride model.
John813
It's odd that ready lift/rough country only lists their leveling kits as 4wd only. Is it cause the 2wd sits lower and a 2" isn't a true level?
ksn240
They probably just haven't updated their information. These trucks are still very new so it will take some time until up to date accurate information is out there.
Samcpatterson
Same question here--- bought 2.5" from supreme suspension--to level front. Lots of confusion for the 2WD. Still not sure if I should have installed. What did you end up going with---and what specs on wheels n tires?
ksn240
It will fit just fine with no issues. There is too much misinformation out right now.
ksn240
subaru79
Oceanside CA
I did the Mopar 2" kit on my 2wd everything is just fine, some online sites are now changing that lifts work for both 2wd/4wd
ksn240
The Mopar lift works no problem. The Readylift and Rough Country 3.5" lots will work on either also. Anything above that though and things change.
Islandflyer
Read this forum all the time, but first time posting. I have a 2WD Rebel and want to level it, is the Rebel suspension the same for 4wd and 2wd? I live in the Bahamas so I can't just order and see if it fits and return. Thanks!
ksn240
Yes it is. The suspension setup is the same for 4wd or 2wd. A regular top hat spacer will be your best bet.
