Leveling kit on 4x2 truck
Mi10
I was wondering if anyone had any experience with installing a leveling kit on a 2019 4x2 truck and what kit to use. Thanks
The suspension setup is the exact same for 2wd and 4wd models so any of the available ones will work. I went with the Readylift kit with new upper control arms.
So any of the lift kits/leveling kits for the 2019 4wd will fit the 2wd?
Correct. The strut assembly is the same regardless. There seems to be some misinformation out there so some people may say otherwise. Anything that says it fits a 2019 4wd will fit a 2019 2wd.
So, let me ask you this now. There was a user on here that installed a 2.5in motofab leveling kit from a 4th gen on his 2019 4wd 5th gen. Would that 4th gen 4wd leveling kit work on the 2019 2wd 5th gen Truck.
Correct. The 4th gen 2wd and 4wd had different setups. The new 2019 model 2wd and 4wd is the same setup as the 4th gen 4wd models. That 2.5" 4th gen 4wd kit will work on ANY 2019 non air ride model.
Thank you for the information!
It's odd that ready lift/rough country only lists their leveling kits as 4wd only. Is it cause the 2wd sits lower and a 2" isn't a true level?
They probably just haven't updated their information. These trucks are still very new so it will take some time until up to date accurate information is out there.
Same question here--- bought 2.5" from supreme suspension--to level front. Lots of confusion for the 2WD. Still not sure if I should have installed. What did you end up going with---and what specs on wheels n tires?
It will fit just fine with no issues. There is too much misinformation out right now.
So I have a 2019 2wd 5th gen. You mention the 4wd 4th gen has the same setup as the 2wd and 4wd 5th gen. Does that mean Rough Country's 6-inch lift for 12-18 4wd will work on my 2019 2wd? https://www.roughcountry.com/dodge-suspension-lift-kit-332c.html
No. I am speaking just about leveling kits, top mount strut extension style leveling kits. The strut assembly is the same in the 2019s, but other components may be different.
I did the Mopar 2" kit on my 2wd everything is just fine, some online sites are now changing that lifts work for both 2wd/4wd
The Mopar lift works no problem. The Readylift and Rough Country 3.5" lots will work on either also. Anything above that though and things change.
Read this forum all the time, but first time posting. I have a 2WD Rebel and want to level it, is the Rebel suspension the same for 4wd and 2wd? I live in the Bahamas so I can't just order and see if it fits and return. Thanks!
Yes it is. The suspension setup is the same for 4wd or 2wd. A regular top hat spacer will be your best bet.
